Use the following procedure to link the security association to an IPsec policy.
  • The IPsec security association and IPsec policy must exist.
You cannot delete or modify a security association if the security association links to a policy. To modify a parameter in the security association, or to delete the security association, you must first unlink the security association from the policy. You can only unlink a security association from a policy if the policy does not link to an interface. If a policy links to an interface, you must first unlink the policy from the interface, and then unlink the policy from the security association.
    enable
    configure terminal
  2. Link the IPsec security association to the IPsec policy:
    ipsec policy WORD<1–32> security-association WORD<1–32>
Link the IPsec security association named new_sa to the IPsec policy named newpolicy:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ipsec policy newpolicy security-association newsa
The following table defines parameters for the ipsec policy command.
Variable
Value
WORD<1–32>
Specifies the policy ID.
Specifies the security association ID.
